BASTUCK
Complete system
Aplicaciones:
Diámetro = 63mm
DESPIECE:
Part No. HOCC/FK-RKAT. Sport catalytic converter (without TÜV approval) only for Typ R
Part No. HOCC/FK-RKP. Tube replacing catalytic converter (without TÜV approval) only for Typ R
Part No. A63-60VW. Adaptor complete system on catalytic converter
Part No. HOCC/FK-1. Front silencer
Part No. HOCC/FK-1P. Tube replacing front silencer (without TÜV approval)
Part No. HOCC/FK-2. Link pipe
Part No. HOCC/FK-3. Rear silencer
Part No. HOCC/FK-AD2. Adaptor rear silencer on original system
Part No. HOCC/FK-RFL. Tailpipe single outlet Flat 135 x 75 mm LH
Part No. HOCC/FK-RFR. Tailpipe single outlet Flat 135 x 75 mm RH
Part No. HOCC/FK-R76EL. Tailpipe double outlet LH 2 x Ø 76 mm with inward curl, cut 20°
Part No. HOCC/FK-R76ER. Tailpipe double outlet RH 2 x Ø 76 mm with inward curl, cut 20°
Part No. HOCC/FK-HE2. Rear valance insert – can be painted body colour, with cut out for 2 x tailpipes LH + RH
Part No. SCH51. Stainless steel clamp Ø 51-55 mm
Part No. SCH63. Stainless steel clamp Ø 63-68 mm
Tramo final, para acoplar a intermedio:
Variaciones de las salidas:
NOTA: The rear silencer HOCC/FK-3 + the tailpipes HOCC/FK-R... can be mounted alone. To mount the rear silencer and the tailpipes the adaptor HOCC/FK-AD2 is required.
Contacto:
GERMANY
BASTUCK & Co GmbH
D-66822 Lebach
Tel. +49 (0) 6881-9249101
Fax +49 (0) 6881-9249119
service@bastuck.deFRANCE
BASTUCK & Co France
F-57500 Saint-Avold
Tel. +33 (0) 387929444
Fax +33 (0) 387929445
bastuck.fr@wanadoo.frhttp://www.bastuck.com------------------------------------------------------------------------------------
BLUEFLAME
Model: BHO018-19-20-21
Shipping Weight: 15lbs = 6800gr.
· Manufactured from T304 grade stainless steel.
· This Full Cat back system in 63.5mm is mirror polished and is probably the finest available for the Civic Type R FN2.
· The Differnce is Dramatic in terms of the cars Drive ability,Immediately you are aware of the increased Trottle Response and the Extra 10Bhp this system gives.
· To further Enhance this,You will benefit from the Glorious Sports Tone,That is Generated from the Free Flow Design of the system.
· All the brackets (APART FROM THE RUBBERS & GASKETS) are provided in the kit to give your Civic a serious sound and style upgrade.
· The unique and generic trims are left in position to maintain the look of this Stunningly Beautiful Pocket Rocket.
Fotos:
Video:
http://s66.photobucket.com/albums/h269/ ... 010018.flvPrecio:
Con descuento: £315
normal: £450
Contacto:
Blueflame Performance Engineering Ltd
Unit 5 Pitt Hey Place, West Pimbo Industrial Estate, Skelmersdale, Lancashire, WN8 9PS
Main Switchboard: +44(0)1695 733 100
Sales Hotline: +44(0)1695 555 551
Fax: +44(0)1695 737 700
CPL Racing
· All stainless steel construction (Grade 304) including flanges
· High quality Tig welds
· Welds are back-purged (back-purging is a process used when welding high quality pipework when full penetration of the weld is required, it results in a totally smooth weld on the inside as well as the outside). The back-purging process used on the CPL manifold is the same process that is used in Formula 1 exhaust manifold construction
· Highest quality fabrication techniques used
· Has optimal compatability with the Hondata Group N ECU, as the ECU was tuned specifically with the CPL Racing manifold
· Pipe diameters and lengths optimized for best horsepower and torque gains throughout entire rev range
· Direct fit with standard and aftermarket catback systems
· Little to no increase in exhaust noise
· Suitable for both naturally aspirated and supercharged cars
· Lightweight
Fotos:
Price for manifold: £749 plus vat, fitting £67.23 plus vat
For limited time only - Price for tuning package consisting of Hondata Group N ECU and CPL manifold: £1239 plus VAT (must be purchased together in the same transaction)
Chart shows power at the wheels
· Before – red line
· After – blue line
A dyno chart is shown below comparing a standard car to one with the Hondata Group N reflash and the CPL Racing manifold.
Linea completa de titanio, con dos salidas.
Fotos:
Videos:
Video de YouTube
Video de YouTube
Fabricada en Japón.
Precio Aproximado:
600,000 Yenes = 4500€ aprox (+ portes)
Contacto:
Company name: D jack corporation
Representative: Oshima hardness
Store manager: Large ridge Takashi
Address: 〒192-0362, The Tokyo Hachiozi checks wood 33-8
TEL: 042-674-7700
FAX: 042-674-7800
DON SILENCIOSO
- Silencioso intermedio solo tubo en diámetro de tubo de 65 mm ó 70 mm: 260.- € + portes + i.v.a. (no homologado)
- Silencioso intermedio homologado en diámetro de tubo de 65 o 70 mm: 480.- € + portes + i.v.a. (homologado)
- Silencioso trasero homologado en diámetro de tubo de 65 ó 70 mm: 860.- € + portes + i.v.a. (homologado)
- Catalizador de alto caudal deportivo (680.- € + portes + i.v.a.).(homologado)
Contacto:
Don Silencioso
Polígono A Grela-Bens, Edificio San Cristobal | 15008 A Coruña
Teléfono: 902 503 439 | Fax 00 34 981 130 026
Iria Villar Acosta
Dpto. Calidad
Tel: 902-503439
web:
http://www.donsilencioso.comE-mail:
calidad@donsilencioso.com ------------------------------------------------------------------------------------
FEEL'S
Están desarrollando un colector de escape así como una linea de escape.
- Exhaust manifold The superb article of the FEEL'S 渾 body which makes high output and artistic lux fuse at high dimension, [shibitsukutaipu] R Europe (FN2) “the exhaust manifold” of business is. It is, the completion which such as detection cutting of the flange part makes also the artistic work think and difference in level processing of the welding part.
With the design which also height of exhaust efficiency pursues, it is the popular item which bodily sensation you can do torque rise. Because all both product the gasket, necessary accessory such as volt/bolt nut and heatproof seat has become set, feeling at rest, you can buy.
- Sport muffler (all stainless steel) The item which improves the good quality of [tsuki] of the engine, torque rise bodily sensation it is possible. Intermediate pipe diameter shows 60.5φ and ideal exhaust efficiency.
<Warning>It is the commodity which to the last does the test development by the normal vehicle. There are also times when it does not pass to vehicle inspection due to the lowering condition of the vehicle and the volume enlargement which accompanies the aged deterioration, the engine and inhalation and exhalation of air tuning of the muffler. Because from thing above, be sure to pass with you cannot promise in vehicle inspection, acknowledgment.
- Sport chamber pipe By the fact that you exchange to the chamber of sport type, the sport characteristic such as good quality of the startup and improvement of feeling is made to raise.
Colector de escape 4-1:
It is hold between the exhaust which furthermore produces the running of [shibitsukutaipu] R Europe sporty.
If you can see the good quality of the completion, as understood, this smooth has lived even in performance of running.
FEEL'S by all power in the midst of development!
Therefore limited 2010 [shibitsukutaipu] R Europe very, bodily sensation we want doing further power rise and performance rise, that with FEEL'S you have asked.
The completion of the section viewing. Secure, the fitting it does, furthermore it administers the processing which makes the flow of the air smooth. Furthermore please try finishing your FN2 sporty.
Fotos:
Supongo que el colector 4-2-1 tendrá algunas leves diferencias respecto al colector del FD2:
Referencia: 32008-KH001
Precio Oficial: £654.50 (incluido el VAT)
Ganancias: +5WHP
Fotos:
Video:
Video de YouTube
Precio:
£595 (
http://www.xopowertuning.co.uk/productd ... 39&yt=2008)
Contacto:
Europe
HKS Europe Ltd
Units 4&5, Sawfield House, Alconbury Hill, Alconbury Weston, Huntingdonshire, Cambridgeshire, PE28 4JL, England
Tel: + 44 (0) 1480 431604
Fax: + 44 (0) 1480 454089
Enquiries:
info@hkseurope.comEngines:
s.french@hkseurope.com------------------------------------------------------------------------------------
INOXCAR
Intermedio:Referencia: TCCIVIC.01
Tubo recto de Acero inoxidable
Precio: 240€
Silencioso trasero:Referencia: HOCI.02.50
Acero inoxidable.
Salidas de 50mm
Precio: 362€
Fotos:
Contacto:
VIA CADUTI SUL DON, 58, 12020 VILLAR SAN COSTANZO (CN)
Tel. + 39 0171 902269
Fax. + 39 0171 902526
inoxcar@aboutweb.it------------------------------------------------------------------------------------
Invidia:
Modelo: Q300tl Catback System
Referencia: HDCB-0601FN
Cat back system Q300tl, the newest in the line up of high performance exhaust systems by Invidia. ECE/ABE approved, so road legal!
* ( works with OEM/Factory rear bumper )
Fotos:
Ahora unas fotos de la linea Invidia para el 1.8 Type-S (prácticamente igual a la del FN2, varía la zona de enganche a colectores):
Precio:
£538 (CPL Racing)
749€ (showoffimports)
Videos:
Video de YouTube
Video de YouTube
Video de YouTube
Web:
http://www.invidia-europe.com/site/inde ... atStatus=2Contacto:
Invidia Europe
Dirección: Maasambacht 11, 2676 AW MAASDIJK, The Netherlands
Teléfono: 0031 - (0)174 - 512530
Fax: 0031 - (0)174 - 518157
http://www.invidia-europe.com------------------------------------------------------------------------------------
JAS Motorsport
Upgraded exhaust pipeline Group N
Precio: 2500€
Linea de escape:
Foto:
Precio: £371.91
This Cat-Back System, is made with SUS 304 Stainless Steel with fully polished surface, CNC machined flanges and are mandrel bent. Its aggressive styling , and deep, strong tone are just part of this Cat-Back system(Connects to standard tailpipes). It is also improves horse power and performance with its straight-through design.
Spec:
* Manufactured from mandrel bent SUS304 grade stainless steel
* This CAT back mirror polished system is 2.5" all the way through from the cat, the twin outlets connect to the OEM tail pieces.
* This Exhaust system will improve throttle response
* Fantastic High Quality Stainless Steel Exhaust
* Full Mirror Polished System
* Gaskets & Bolts included
* 100% Brand new in original box
Fitment:
Honda Civic FN2 Type-R 2007-
Install images and sound clip on request
Warranty: Life Time - First Buyer
También comercializan un
supresor de catalizador:
Fotos:
Precio: £146.80
JPerformance Decat / Test Pipes offer the ultimate in high-flow performance. Offering substantial horsepower gains in the higher-end of the power band. The JPerformance Test-Pipes are made of Stainless Steel with a quality polished finish and a straight through design, but serve to give your custom exhaust system a more mellow-deep tone
Spec:
* Provisional Dyno Results +6BHP
Fitment: Honda Civic FN2 Type-R 2007-
Warranty: LifeTime - First Buyer
Realizan envíos a todo el mundo.
CONTACTO:
sales@jperformance.co.ukEmails checked every 30minutes
08:30-17:00
web:
http://www.jperformance.co.uk------------------------------------------------------------------------------------
Referencia: CFX-FN2-70RR
Precio: 155,400 Yen (Excluding tax: 148,000 Yen) = 1286€ (1224€ sin impuestos)
Descripción:
To the full titanium series of great popularity
"70RR" of goods only for the game finally appears.
It is a muffler only for the circuit of the straight structure smoothly bent by mainly adopting the thickness pipe of 1mm made of 70φ titanium, and using three dimension vender.
There is no processing ..narrowing piping (The diameter is thinned in the silencer).. at all.
It is an excellent article that doesn't consider use on the street, and sticks to the power-up and lightening to the utmost limit.
The right and left is put out, it changes from a dual type to a right single type in purity for the power-up, and the rejection pressure is decreased rapidly.
They were made to unite a great lightening to the power-up by decreasing the number of parts in addition to a light titanium material.
It aims at the rejection pressure decrease to the limit, and the tail is assumed to be a right single type that the total length of the muffler can be shortened.
If suction system Cheung such as the air cleaners and the large caliber throttles and ignition system Cheung such as ECU and plugs are given, I will promise power-up & torque improvement by the whole area until low revolution - rotating high.
A further lightening and the exhaust resistance decrease were achieved by assuming the type.
It is a special muffler that appeared to win in the circuit.
- Made of all titanium
- It installs it in front of the catalyst.
- Right putting out single type
- Lightness one the mm thickness titanium pipe is adopted for the material.
- It is a structure matched to the exhaust exit of a pure bumper, and it is possible to install it by no processing.
Warning and notes
- Goods only for game
- Though the mark of a treatment device thin on the manufacturing process might adhered
There is no problem in the quality.
- The repair of damage due to contact etc. is received in actual expenses.
Please feel free to consult.
- The price is a predetermined price. There is a possibility of changing when putting it on the market.
Foto:
Referencia: CFX-FN2-60RS
Precio: 134,400 Yen (Excluding tax: 128,000 Yen) = 1112€ (1060€ sin impuestos)
Descripción:
It finally appears in the full titanium series of great popularity for FN2 TYPE-R EURO.
Made of super-light all titanium/twin silencer exhaust system
It is 60R S Series to take a sight to the street scene, and to have achieved best power and the volume.
This product set the specification for the street user.
A low-speed inside is not sacrificed and power-up & torque is improved by the whole area by changing the caliber of the main pipe to purity 54φ→60φ and adopting the pipe removing turning of a straight structure.
(our company DYNAPACK TEST result 6.2ps power UP)
Moreover, it became possible to decrease the rejection pressure rapidly as a result of putting out the right and left and doing purely the layout change to "Left single type" from a dual type, and they were made to unite a great lightening to the power-up.
I will promise a power feeling felt comfortable in which the feeling is valued and a dry VTEC sound.
- Security standard acceptable goods
- After the catalyst, it installs it.
- Left putting out single type
Warning and notes
- The inner silencer cannot be installed.
It is produced to become security standard acceptable goods by the muffler unit, and it exists when it doesn't ask for the measurement environment and the usage condition and the use period and measurements are different.
Please note that it is not in goods for a complete to the last car inspection.
Fotos:
Contacto:Distribuidores para Europa:GreeceR-SPEC PERFORMANCE
Dirección: 19, GUNARI STREET ANO GLIFADA ,ATHENS ,GREECE 16562
tlfno: 30 210 9605549
UKSUMO Power Ltd.
Dirección: Kleer Houle Sheerness Docks, Sheerness Kent ME12 1RS
Tlfno: 8712260171
IrelandTuning Factory
Dirección: UNIT B4, J.F.K TRADING CENTRE J.F.K INDUSTRIAL ESTATE,NAAS ROAD, DUBLIN 12 Republic Of Ireland.
Tlfno: 003531 4298989
Germanynnomo-racing
Schmalzgrube 6, D-77694 Kehl, Germany
Tlfno: +49 7851/898825
Jtune
Dimensiones: 2 x 2.25”
Lo que comenta sobre las dimensiones de la linea el comercial:
The volume of the twin 2.25” is greater than 3” and due to the reverse collector in our cat back system this creates very little back pressure, after the cat. In fact we back to back tested our system against our single Prototype Single 2.5” system, vs our 3” single system vs our duel 2.25” system and was the same performance as the 3” system.Fotos:
Video:
Video de YouTube
PRECIOS:
As for an indication of price the Extreme kit which includes Intake + Battery Relocation kit + Header + Cat + Exhaust + both rear muffler sections and our Extreme flash ECU including all gaskets and bolts has a RRP of $5500 + shipping
The JTune Fn2 cat back exhaust system which includes the cat back system and the adaptor pipe to the standard Honda cat will be around $1550 + shipping. The cat back exhaust system also includes the interchangeable rear pipes.Datos:
As for performance yes we have these results.
Our Standard FN2 on our dyno produces 140kw at the wheels
Our Extreme FN2 kit produces 160kw at the wheels
Our Ultimate FN2 kit produces 170kw at the wheels
Our Standard FN2 Supercharged kit produces 180kw at the wheels
Our Extreme Supercharged FN2 kit produces 220kw at the wheels. Como curiosidad os dejo unas fotos de la admisión de Jtune y el recolocador de batería (aunque ya haré un tema con las admisiones):
Contacto:
Martelius:
web:
http://www.martelius.com/index.php?type=1&id=8Our systems are designed for group N rally use only. Pricing as follows:
· Modification to the front exhaust, original part needed for platform. Product code 180034, price 120 €
· Midpipe, no silencers. Product code 180035, price 136 €
· Rear exhaust without catalytic converter, product code 180036, price 410 €
· Alternative to the previous: Rear exhaust with FIA homologated converter, code 180036K, price 960 €
Foto:
Miltek:
Honda Civic Type R 2.0 i-VTEC FN2 performance exhaust systems and high-flow sports catalysts (2007 and later)
CAT-BACK - Uses original tailpipes
Consiste en:
- Centre Section
- Connecting Pipe
- Rear Silencer (exc. tips)
- LH Outlet Pipe
- RH Outlet Pipe
- LH Pipe to OE Tip
- RH Pipe to OE Tip
Pipe Diameter: 2.50" (63.50mm)
Ganancias: +6.8bhp +7.3 lb/ft
Gráficas (la roja es con la linea de serie, la verde es con la Miltek):
Video 1:
Video de YouTube
This video shows the latest Honda Civic Type with Milltek exhaust fitted. Please note that this car is fitted with experimental tailpipes but the final product uses the original triangular tailpipes.
Video 2:
Video de YouTube
Video shows the new Honda Civic Type R (FN2 model) with a Milltek Sport stainless steel performance exhaust system fitted.
Fotos:
This photo shows the new stainless steel Milltek Sport cat-back exhaust system for the latest Honda Civic Type R (FN2). The system consists of a centre section (top, connecting pipe, rear silencer, LH and RH outlet pipes and LH and RH connecting pipes that connect to the original triangular tailpipes
Precio:
£399.00 (comprando en tdinorth)
Contacto:
Factory and Fitting Centre
Units 1 - 3, Belfield Industrial Estate, Ilkeston, Derbyshire, DE7 8DU {view map via Multimap}, England
Please Note: Fitting and manufacturing attendence is by appointment only. Please call us on the phone number(s) listed (above-left) to arrange an appointment.
Warehouse and Distribution
Unit 8, Victoria Centre, Victoria Way, Pride Park, Derby, Derbyshire, DE24 8AN {view map via Multimap}, England
Email:
info@millteksport.comTelephone number: 0044 1332 227 280
Fax number: 0044 1332 227 289
.jpg)
Foto:
Gr.N - Gr.A:
Piezas oficiales Mugen FN2:
Referencias y precios de los colectores y linea de escape:
Contacto:
http://www.mugen-power.com------------------------------------------------------------------------------------
Fabricado en acero inoxidable T304 (and features mandrel bent curves for optimum gas flow).
Ganancias: En un dyno-test independiente de la marca, se consiguieron ganancias de 14cv (when used in combination with the manifold and SportsCAT).
Precio del colector de escape: £340.00 plus VAT.
Precio del catalizador deportivo: £250.00 plus VAT
Precio del escape: £395 plus VAT.
The fit-to-CAT system features twin silencers which connect to the factory triangular tailpipes.
A Piper de-CAT pipe and a single silencer exhaust fit-to-CAT system are also available for track day cars.
All the above components are avaliable from our Honda tuning specialist partners:
Foto:
Se puede adquirir en:
ABP Motorsport Ltd.
http://www.abpmotorsport.co.uk (01270 567 177)
CPL Racing.
http://www.cplracing.co.uk (01795 668778)
Contacto:
Telephone:
(within UK) 01303 245300
(from outside UK) International dialling code +44 1303 245300
Fax:
(within UK) 01303 240666
(from outside UK) International dialling code +44 1303 240666
Address:
Piper RS Ltd, Units 5 & 6, Bowles Well Gardens, Folkestone, Kent CT19 6PQ., United Kingdom
Web:
http://www.piperexhausts.co.uk/exhaust/index.php------------------------------------------------------------------------------------
QUANTUMAUTOSPORT
Colectores:
Description:
High-grade steel sport specialized elbow union 4-2-1 with increased pipe diameters and gentle radii for improved exhaust throughput and more achievement.
In combination with the optional Katersatz or 200 cpsi these parts an additional output of 12-14 HP bring metal catalyst (and Cat baking an exhaust system).
Note: Only suitably for Type-R (FN2).
Opciones:
- Supresor de catalizador: 100€
- Catalizador metálico de 200 celdas: 350€
Information to the TÜV entry: TÜV entry after §21 necessarily.
Disponibilidad del producto: Delivery time about 2-4 weeks
Precio: 599€ (Posibilidad de envío internacional con cargo adicional)
Foto:
Contacto:
Side operator - §6 Nr.1 TDG
Dirección: QUANTITY Trading GmbH, Managing director: Vassilios Bertakis, Dornhofstr. 32, Building/unit R0-R2, 63263 new Isenburg, Germany.
Communication - §6 Nr.2 TDG
Email:
info@quantumautosport.comTelephone: +49 (0) 61 02-83 77 60
Fax: +49 (0) 61 02-83 77 61
Tax number - §6 Nr.6
Tax office: COMPANY Offenbach, Hessen
USt IdNr. (VAT-ID): DE259826068
Ragazzon
Los silenciadores Ragazzon son sometidos a un severo proceso de prueba, por parte de los encargados de la Motorización, a fin de obtener la homologación CEE.
Los tubos de conexión de acero inoxidable aisi 304.
La parte silenciadora, se obtiene primero de cintas de acero inoxidable pulidas, mientras que para la parte interna de los mismo se utilizan varios tubos perforados de acero inoxidable aisi 409 recubiertos con lana inoxidable resistente a las altas temperaturas y con material fonoabsorbente.
El silenciador se cierra con placas de acero inoxidable totalmente soldadas con Tig.
Gestión de pedidos "Just in time" que permite garantizar el mínimo plazo de entrega.
Posibilidad de personalización de los sistemas de escape en caso de grandes pedidos, grabando el nombre del foro por ejemplo.
Intermedio Gr.N:Referencia: 55.0134.00
Acero Inoxidable
Precio: 180€ + IVA
Fotos:
Silencioso Trasero:Referencia: 58.0353.00
Salidas de 45mm
Acero Inoxidable
Homologado para toda la CEE.
Precio: 530€ + IVA
Foto:
Foto General:
Contacto:
Ragazzon Srl
Via Dei Colli 29/33 - 31058, Susegana (TV) Italy
Tel. +39 0438 73523
Fax +39 0438 73342
info@ragazzon.itP.I. 03488650262
Distribuidores en España:
AUTOCORSE
Parque Empresarial Neinor, Edificio 7, Nave 9, 28880 Meco Madrid, España.
+34 629 022 571
+34 651 938 048
autocorse@idasal.comhttp://www.autocorse.es------------------------------------------------------------------------------------
Revolution Motorstore
Desarrollado en colaboración con Scorpion Exhausts.
Material: Acero inoxidable T304
Ganancias esperadas: 10% ó 15%
Precio: £479.00 including VAT (según el cambio a día 15 de Julio de 2009 = 558€ IVA incluído)
SEBRING
Article number: 0714021
Entre un 20 y un 25% menos de presión de retorno.
Price: 568€
Precio si lo compras en fnhatch.de = 431€ (ver post:
http://66.196.80.202/babelfish/translat ... 144#p33144 )
465€ en Autohispania
Carriage free within Germany
Envío a Europa = 40€
Fotos:
Contacto:
Ruhmannstrasse 11, A-8570 Voitsberg
T: +43-3142-28280-0
F: +43-3142-28280-490
E:
office@sebring.atSHOP-HOTLINE
Austria: 0820 500 602
Germany: 01805 509 300
England: +43 820 500 603
Italy: +43 820 500 604
e-mail:
shop@sebring.at------------------------------------------------------------------------------------
Spoon ya tiene un FN2 en sus instalaciones y están empezando a anunciar sus productos... entre ellos un escape para el FN2.
Foto:
Precio: ¥155,610 (Touge distribution)
Contacto:
Spoon Sports Europe Ltd.
Units 15&16 Bridgwater Court Oldmixon Crescent Weston-Super-Mare Somerset BS24 9AY UK
Tel.44 934 410 090 / Fax.44-1934-410 091
http://www.spoonsportseurope.net/------------------------------------------------------------------------------------
SUPERSRINT:
Connecting pipe with metallic kat.(For OEM manifold)
cod: 925421
Precio oficial: £1,015.14
Precio en Sportech Import: 1318 euros (iva y envío incluído).
Precio en autohispania.com: 913€ (iva y envío incluído)
Centre exhaustcod: 925403
Compatible con el Catalizador de serie.
Precio oficial: £400.29
Precio en Sportech Import: 520 euros (iva y envío incluído). Precio a día 16/12/09 = 515€
Precio en autohispania.com: 392€ (iva y envío incluído)
Centre pipeAlternative to 925403.
cod: 925413
Precio oficial: £270.28
Precio en Sportech Import: 351 euros (iva y envío incluído). Precio a día 16/12/09 = 330€
Precio en autohispania.com: 286€ (iva y envío incluído)
Rear exhaust.(For OEM endpipe)
cod: 925404
Precio oficial: £810.34
Precio en Sportech Import: 1052 euros (iva y envío incluído). Precio a día 16/12/09 = 980€
Precio en autohispania.com: 741€ (iva y envío incluído)
Linea completa = +7cv.
Power flow graphics
OEM
Claimed data:
Horsepower 201 Hp @ 7800 rpm
Torque 195 Nm @ 5600 rpm
Actual data:
Horsepower 208,2 Hp @ 7865 rpm
Torque 191,4 Nm @ 7350 rpm.
Gráfica:
http://www.supersprint.com/include/file ... asp?ID=357 Supersprint:
- Connecting pipe + metallic kat 925421
- Centre exhaust 925403
- Rear exhaust R.- L. 925404
Actual data:
Horsepower 214,9 Hp @ 7875 rpm
Torque 204,1 Nm @ 5910 rpm.
Gráfica:
http://www.supersprint.com/include/file ... asp?ID=358Supersprint:
Actual data:
Stock Vs Supersprint.
Gráfica:
http://www.supersprint.com/include/file ... asp?ID=359Web:
http://www.supersprintuk.com/civic-type ... 4_496.htmlDistribuidor para España: SPORTECH IMPORT
Persona de contacto: Alex Maguregi
MARKINA (VIZCAYA)
Tel. +34 946 169 113
Fax. +34 946 169 034
http://www.sportech.es Mejores precios en: autohispania.com
TDInorth
Fotos:
Gráfica:
Precio:
625€ +18% de impuestos + portes
Contacto:
TDi-North
21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG
Tel: 0800 0196055
Email:
info@TDi-North.comweb:
http://www.tdi-north.com/------------------------------------------------------------------------------------
Team Dynamics
Stainless steel exhaust system - Full system available, manifold (+ de-cat or Sports cat), and a cat back system, all interchangeable. Mounts on existing road car mounts. Power increase not yet confirmed.
- Cat back exhaust system - £950
- Sports cat - £500
- Track day de-cat - £250
- Exhaust Manifold - £950
TODA:
Colectores:
Referencia: 18100-FN2-000
Precio: 1,062€
Precio Japón: 120,000 JPY = 955€
PDF:
http://gasss.foroctr.com/fotos/TODA%20F ... ader_e.pdf
Escape:
Referencia: 18000-FN2-000
Precio Europa: 1,035€
Precio Japón: 108,000 JPY = 860€
Peso: 18'5 Kg
PDF:
http://gasss.foroctr.com/fotos/TODA%20F ... stem_e.pdf
Gráfica:
-hondata ecu
-toda header and exhaust
-P2R TB spacer
-stock intake
Vs
Stock
Otra gráfica que muestra: Diferencia entre el CTR FN2 anterior y otro con el colector de escape de CPL+milltek+hondata ECU+heatschield+RRC intake manifold and BMC panel filter:
Video de todos los componentes de los colectores + escape TODA:
Video de YouTube
Video con el escape toda (colectores OEM):
Video de YouTube
Video linea completa TODA (colectores + escape):
Video de YouTube
Video de YouTube
UBER GARAJE
Diámetro: 2.5"
Material: Acero Inoxidable T304
Desde el colector, suprimiendo catalizador.
Explicación de la gráfica según UBER:
The car is running on our Custom 2.5" Extractor back exhaust, Piper Extractors, K&N Typhoon intake kit, Driven Front Air Scoop & Hondata Flashpro tuned by Joel!
Before the Piper Extractors and Custom Exhaust, the car was making 172hp 16/kgm of torque on wheels...
After the Extractors and Custom Exhaust... 184 hp & 17.6kg/m of torque on wheels!!!! 12whp and 1.6kgm gains!!!
Fotos:
Gráfica:
Contacto:
http://www.streetdirectory.com/asia_tra ... e_11591/5/7 Chang Charn Road (Off Leng Kee Road)
Singapore 159636
T: 6475 8077
xopowertuning
Son los mismos que comercializan en TDInorth (UK).
Fotos:
Gráfica:
Precio:
Price (exc VAT): £625
Contacto:
Unit 382e Jedburgh Court, Team Valley Trading Estate, Gateshead, NE11 0BQ
Tel: 0191 482 2266
Email:
sales@xopowertuning.co.uk------------------------------------------------------------------------------------
Artesanales
Artesanal:
INGARSA Sport
Contacto:
Rúa Romana, 79
31390 Olite (Navarra - España)
Teléfono: (+ 34) 948.740.728
Telefax: (+ 34) 948.740.745
Móvil: 617321198
E-mail:
ingarsasport@ingarsasport.com------------------------------------------------------------------------------------
Walter (clubcivic.es)
Contacto:
Walter@clubcivic.esWalter@tmracing.es------------------------------------------------------------------------------------
Akrapovich employee
Artesanal (desconocido)
